jesseannie
Apr 25, 2014Explorer
How to Direct Wire Inverter
I have a 400 watt continuous 800 watt peak Cobra inverter. It has 2' long clamp on style connectors for attaching directly to the battery.
I would like to direct wire the unit and install it inside the trailer about 12' from the pair of TT batteries or alternately wired to the electrical panel that is located under the bed. (easy access)
I will only be using the invertor to charge my phone, camera and to power two laptops. I am not going to try to operate any appliances.
In my last trailer I had a unit that I was able to wire to the main electrical panel in the trailer. This unit did not come with any option to do that.
Any help would be appreciated.
PS Yes I did do a search and so many of the questions had to do with larger units and solar power.
jesse
jesse
