Salvo
Aug 19, 2015Explorer
The meter has something like 10 M ohm input resistance. It will pick up radio waves. That's what you're reading. However, that's not what gave you a tingle. Either you imagined it or there's something else wrong with the electrical system. Probably an open, or sometimes open ground in the extension cord going to the garage.
If there's an open ground then you'll see 60Vac from chassis to ground. This can give a slight tingle when ground is wet. The 60V is created from a capacitor voltage divider within the converter. Nothing to worry about as it has about 5 kohm resistance.
Ron Nielson wrote:
What is the problem here? I wouldn't think you would feel about 1/4 of a volt, but I did, at least when the ground is damp. How could there be AC Voltage (as small as it is) when the trailer is not plugged into shore power? Where to start? How does one figure this thing out?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
