Mickeyfan0805's avatar
Aug 11, 2013
HWH - does it need to be powered off in transit?
I need to admit my ignorance as to the electrical set-up of the hot water heater (and most electrical in the trailer, for that matter). I always turn off the power switch on the HWH when I complete a trip because I plug in at home and don't want to run it and heat the water for no reason.
With that said, we're headed out on a trip where we'll be moving from one campground to another a number of times. I'm pretty sure I need shore power for the HWH to run, which would mean I could just leave it on while in transit (dsi off, of course) and it will power back on when I plug in at the next site.
Is this correct, or do I need to power it down for transit for some reason?
  • Bobbo's avatar
    Bobbo
    I turn off the propane burner whenever we aren't showering to save propane. I turn off the electric element before unplugging from the pedestal so there will not be a surge of current when I plug back in to the next pedestal. While plugged into the pedestal, I leave the electric element on all the time, since the CG is paying for the electricity.
    We generally leave our HWH off all the time until it's getting close to dinner time or shower time. I am of the belief there's no reason to leave it on 24/7 when I'm not using it. When we travel, everything is switched off except for the refrigerator.
  • I would shut it off. Why? when you plug into shore power receptacle, you do not want a heavy load. Yes, this is one of the reasons you should turn off the breaker in the pedestal.
