Slownsy wrote:
time2roll this is exactly what I am doing, the 15A cord goes in to the generator which powers the inverter and charger.do the load sharing happen automatically and I don’t have to do anything?
Thanks Frank.
I have this inverter and use it everyday. You need to adjust your incoming load share. I have both a Honda eu2000i and eu2200i. Elevation will play a factor also. On my system I have 1,280w solar also, if I'm going to run my 15k A/C for long periods of time I'll set the incoming ac to 15a, the generator is power the A/C or the first 15a and solar picks up the balance of the draw if there is tv, humidifier, laptops and if the batteries need charging the balance of power being produced goes to them.
On occasion if I'm going to need to put a charge into the batteries I set the incoming ac to 15a and that will charge at 100a or whatever the balnce that isn't being used by loads running, this is with the eu2000i if using the eu2200i I could set it at 18a if I wanted.
You can experiment with the incoming ac by turning the nob that adjusts the incoming amps, start at 10a for instance, listen to the the generator noise, as you adjust up or down amps on the display you will here the generator either idle up or down.
