joe0508
Nov 25, 2015Explorer
hydroboost diagnosis test
I have been having a problem with my brakes here lately and i am in the process of taking it in for a diagnosis.The problem is the brakes doesnt seem to have the stopping power they should have and they are spongy.They seem to go the better part of the way to the floor before i get any response.If i hit them hard the brake light will ficker on the dash.One time it came on and stayed on and wouldnt go off untill one day i was missing around and while it was idling i pumped the brake very lightly a couple of times and it went out i thought that was strange.I have checked the fluid in the master cylinder and it is full almost to full.The power steering fluid is good.The belts and dont see any leaks.I have tryed a diagnosis test on the hydrobooster that i found on the net and when i turn the engine off and pump the brakes to discharge the accumulator it says the pedal should harden noticeably but it doesnt make a difference although when the motor is running it will pump up.At least when im going down the road.Havnt tryed it at a stand still yet.Anybody have any ideas?I dont wont to replace the booster if it is the master cylinder.
