- GjacExplorer IIICheck the green pressure switch they often leak and require replacement. If you take off the access plate you can see it look for transmission fluid on the switch. Also check the fluid level.
- beav1017Explorerthanks
- RLS7201Explorer IIIf the mechanic you find is not fully informed about the auto-park system, share the links below. All the details needed to trouble shoot your auto-park is at those 2 web sites.
Oemy's
Old Used Bear's auto park info.
Richard
Having RV issues? Connect with others who have been in your shoes.24,195 PostsLatest Activity: Feb 04, 2025
