John_Joey
Jan 22, 2015Explorer
I need to replace an igniter that is no longer made. UPDATE
Spec's
Part number 2933096014
2005 Dometic Fridge RM2454
Prod#9211401-19
Helping a neighbor fix his fridge and I worked it back to a bad igniter. The problem is Dometic no longer supplies this part, and if I do see one on the net, it's way overpriced ($150.)
My plan is to replace the igniter with the following one (note that his model number is not in their list of compatibility.)
Clicky
I can not see why it should not work. Anyone have prior experience with this problem, or any other "useful" tech input.
ASAP noted that they did not know if it would work, and do not take responsibility for the results. Dometic has no input on this problem either.
Thanks in advance.
Prod#9211401-19
Clicky
Thanks in advance.
