HiLetgo DC 6.5-100V 0-20A LCD Display Digital Ammeter Voltmeter Multimeter Current Voltage Power Energy Battery Monitor Amperage Meter Gauge with Built-in Shunt
by HiLetgo Product description
Style:DC 6.5-100V 0-20A
Specifications:
Voltage: test range 6.5 ~ 100V
Measurement Accuracy: 1.0
Measurement speed: 2 times/s
Store Energy data when power off. Can be reset to 0
The blue backlight can be turned on/off manually
Test Range and Display format:
Active Power test range: 0~2kW
Energy test range: 0~9999kWh
Voltage test range: DC 6.5~100V
Current test range: 0~20A
Note:
This module is only suitable for 6.5~100V DC power.
This module is suitable for indoor, not outdoor.
Applied load can not exceed the rated voltage and current.
The wiring order can not be wrong.
Packing Included:
1 DC 6.5-100V Power 20A Power Multimeter
This meter has a built-in shunt. 0-100 volts to 20 amperes.
BUT the amperes are measured BEFORE a MPPT meter.
The direct readings from an array are interesting and the total accumulated kWh is not volatile. The meter and it's information is segregated from a panel battery amp hour display. So implied solar panel function or dysfunction screams out at a user. And yes, the voltage reflects high voltage from the panels and direct high voltage DC amperes thus watts from the panels. BEFORE they go into an MPPT controller.
I found this on AMAZON...$12.49 and free shipping
