E_J_push_n_wind's avatar
Jan 23, 2015
Inverter/Converter help?
I'm looking to add a PSW inverter to my TT, I'm thinking somewhere in the neighborhood of 3KW. I don't necessarily need something perhaps that big however I'm thinking if I wanted to add battery capacity, this part I would not have to do again. Kind'a do it once and be done. I'm wondering if I could get help in directing me on how would be best to wire it? I'm wanting to isolate my converter when I have the inverter "on." I know it is recomended to have the inverter as close to the batteries as possible (for the current draw on 12V DC vs. 120 VAC) however I am thinking of running heavy wire and place the inverter in the enclosure with the connverter. I would like to somehow have a single switch as a cut-out (if that is possible) so as to "turn off the conver" as the inverter is switched on (a single throw switch that does both?). Is there a way to do what I'm looking for? Any help would be much appreciated.
The TT has two 6V deep cycle marine batteries right now. The idea is to have all outlets energized through the inverter realizing that my "power supply" is limitted by the number of amphours available with the batteries I have on board.
