Gerald55's avatar
Gerald55
Inverter hookup
A couple of questions about installing an inverter. I'm looking to put one in my 2008 Pleasureway Excel, which didn't originally come with one wired into the 120V system (it did have a small 400W standalone one for the TV only).
Can I simply wire the output of the inverter right into an existing 120V outlet in the RV, e.g., using a male-to-male cord like this:
http://www.amazon.com/Dual-Male-12-Gauge-Connection-Extension/dp/B0035Z13FI/ref=cm_cr_pr_product_top?ie=UTF8
In that case, what happens when I connect to shore power and the inverter is on? Will it just play nice by default, or does it need some kind of internal transfer switch capability to not blow up?
I do an unused transfer switch in my rig since it's wired for a generator but doesn't have one, so maybe I can just use that input?
Any recommendations on brands? I'm looking for 1500W or so, and don't want the dirt cheap variety, but maybe the next level up. I especially want one whose fans are variable, i.e., they only go on if needed to cool the inverter and would generally stay off or run at a low speed if I'm pulling 100W rather than 1500W (which will be very common, e.g., just a laptop).
Some of the "good" inverters I've seen seem to run the fans at nearly full blast regardless of draw.
Having RV issues? Connect with others who have been in your shoes.24,239 PostsLatest Activity: Apr 25, 2025
