wa8yxm
Sep 03, 2015Explorer III
Where did you measure voltage at?
IF you measured at an outlet.. The problem might be the inverter... and then again it might NOT
Serious fact: I plugged in a heavy load and lost ALL power on the inverter powered circuits.. Turns out a connection was fried,, I cut back and re-dressed the wires and re-connected an all is good,, been 8 years and it's the circuit powering this computer as I type. So I knwo it's good.
Had the connection only "Half fried" I'd have seen what you see.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 11, 2025
