BFL13
Sep 13, 2014Explorer II
The voltage sag when the water pump came on was enough to shut off the inverter (10.5a shut off? ) powering the TV. Use fatter wires from inverter to the DC panel battery lugs so there is less voltage sag (because fat wires have lower resistance than thin wires over the same length)
