chilly81's avatar
chilly81
Inverter wire into RV 'house' circuit question
I would like to feed my small 300W inverter into an isolated 'house' circuit that I've identified that powers a few convenient 120v outlets on one side of my trailer (and is isolated from microwaves, converters, etc).
My plan is:
-Cut the 120v wire for this one circuit as it comes out of the breaker (15a) and heads into the wall.
-Put a DPDT switch inline at that cut (the 2 +/- wires).
-Wire the 2 +/- output wires from my inverter to the other input of the DPDT.
-Now I can flip a switch and that circuit goes from normal shore power to inverter powered. And if I forget and leave it in the wrong setting at some point, I can't damage anything (like accidentally powering my converter from my inverter, etc)
So wondering if I've overlooked anything. And also want to ask what I should be doing with the grounds. The DPDT has only 2 poles for the +/- wires. What to do with the bare copper grounds? Should I splice the 3 (the two inputs and one output) together, even though the switch itself isn't grounded?
Also, should the chassis ground of the inverter itself be wired to the same bare copper ground wire as the 120v bus is.
Any advice would be appreciated.
Thanks
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
