coljhoss
Feb 21, 2014Explorer
inverter
if im correct the inverter inverts battery power to 120 for certain outlets. if inverter is bad but im plugged into shore power will it trip gfi or not allow outlets to work.
BJean wrote:
Does anybody know what type of fuse should be used in the instalation of a 400W inverter.
coljhoss wrote:How bad is bad? Yes if the fault is correct it may trip the GFI. Not likely though.
