landyacht318
Jul 17, 2016Explorer
racer4 wrote:
landyacht318,
Did you mean 'should not" or 'should' be able to accept 23A?
That amount of capacity, if still healthy, Should not be able to accept more than 21 amps if 95%+ charged.
I would not fear getting a power supply rated at higher amperage.
I can do the 5% constant current thing by fiddling with the voltmeter, but generally I would just bump voltage to 16v and if it required more than 5% of capacity to reach 16v, then I'd give it more time in the high 14's then try again, but I have done the voltage twiddling thing to keep it at around 5 amps.
