- FreightguyExplorerI have;
Coleman Mach 8 15K AC unit x 3
Dometic Control Kit # 3312020
Dometic Wall Thermostat # 3314082.011 Freightguy wrote:
This is the situation I wish to have.valhalla360 wrote:
Ours has 4 options:
- Hi Always on
- Low Always on
- Low Auto
- Hi Auto
With the always on, even when the thermostat turns off the compressor, the fan keeps going.
Then we need to know model of the AC(Brand also) and what type wall tstat you have now. Doug- FreightguyExplorerThis is the situation I wish to have.
valhalla360 wrote:
Ours has 4 options:
- Hi Always on
- Low Always on
- Low Auto
- Hi Auto
With the always on, even when the thermostat turns off the compressor, the fan keeps going. - valhalla360NavigatorOurs has 4 options:
- Hi Always on
- Low Always on
- Low Auto
- Hi Auto
With the always on, even when the thermostat turns off the compressor, the fan keeps going. - Simple answer--Maybe. If you want HI fan continous, then you have to use Hi Fan/Cool. List your system and wall tstat. Some systems, the Fan will always run on either Hi or Lo(selected speed by user) in cool mode and shuts both the Fan and Compressor off when temp is reached. Some will cycle thru the Fan speeds (hi/med/Lo or Hi/lo) when on Auto cool. It depends on the system. Doug
- wildtoadExplorer IIMight also want to make sure filters and coils are clean.
- Check your freeze sensors first. They should be positioned right in where the ice is forming. Access by removing the interior trim. Either way the condensate will flow off the roof unless you have some type of other drain that is plugged.
You may need to post exactly what thermostat brand and model you have. The Dometic units should be switching the high fan when the interior is 4+ degrees higher than the set point. - theoldwizard1Explorer IIA/C icing is usually an indication of low refrigerant.
