landyacht318's avatar
landyacht318
Judging Deep Cycleability by weight per capacity ratio
I am stuck with 12v batteries.
No way, No how are 2 6V batteries fitting in my rig.
The screw31's fat lady is in the dressing room preparing for her performance.
I was looking to replace screwy31 with a SCS 225 from Trojan which is just about the same size, except the handles add one inch to the length and I might have to shave off one handle to accommodate it. Not desirable, but more desirable than another Screwy31.
Now, it is no secret that the group 24/27/31 sizes are not built anywhere nearly as burly as the T-105's.
If we divide the capacity by the weight
T 105s 225AH/124LB's we get 1.84 AH per pound
SCS-225 130AH/066LB's we get 1.97 Ah per pound
T-1275 150AH/082LB's we get 1.82 Ah per pound
Now the T-1275 might fit my intended location, if I Modify and lower my battery tray. I do not really need the 20 extra AH of capacity, but the closest place I can acquire the T1275 battery, offers it as the same price as the SCS-225(3$ more core charge) for the extra 18Lbs of lead.
From the AH per weight category, I think perhaps the T-1275's plates are thicker and has a better lead/electrolyte ratio and should have a much better cycle life than the SCS225/ group 31
What say you Mex, is a lower AH to weight a good indication of how burly the guts of a battery are?
Do you think the T-1275 could compare to the T105 in plate thickness?
I wonder how much space is below the plates on the T-105 vs the T-1275.
I might stop cycling the screwy 31 and plug in the Meanwell overnights, as fabricating a new battery tray and purchasing a new battery will squeeze finances too tightly for the next two weeks or more.
http://www.trojanbattery.com/pdf/datasheets/SCS225_Trojan_Data_Sheets.pdf
http://www.trojanbattery.com/pdf/datasheets/T1275_Trojan_Data_Sheets.pdf
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
