MEXICOWANDERER
Apr 30, 2018Explorer
Just Finished A Breaker Box Test Of Security
Out of curiosity
Every morning at 0630 the Oster was fired up for one half hour and I made toast and between 10-30 minutes the assembly baked at a reduced 250 degrees.
The wire ranged from 6AWG to 12 AWG THHN THNN and TWNN
This morning after the buss cooled I removed it. Used a straight Snap On flat blade screwdriver.
All six unsoldered wire set screws were SIGNIFICANTLY looser than the soldered wires set screws. We're not talking a subtle difference here.
SIGNIFICANCE
Now you know.
- 12 connection brand new tin plated aluminum bus
- Twelve wires were used
- Six wires were stripped and clamped tight TIGHT with set screws
- The remaining six were stripped, had the tips soldered
- After soldering a flat file was used one side to make a flat spot for the set screw
- Not that much material was removed
- Six wires were inserted then the set screws were tightened every bit as tight as the unsoldered wires.
SIGNIFICANCE
Now you know.
