bigbillsd's avatar
bigbillsd
Need a small breaker panel to finish Inverter Replacement
I am looking for a small breaker panel that will take a 30amp main from my inverter output terminals and has room for at least 2 @ 20AMP breakers to protect the coach outlets. It needs to be surface mount and "pretty small" to fit into the inverter compartment area. The old inverter had two built in 20 amp circuit breakers for the output lines, the new higher capacity inverter does not have that feature so I need to protect those 120 volt circuits very close to those output terminals.
Here is a pic from the manual of the setup I circled the part in Yellow that is need to find a source to purchase it from.
-Bill
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
