firedog's avatar
firedog
keyless entry
We are having issues with our keyless entry or I think our problem stems from it. When we insert the key and turn to lock or unlock it makes a grinding noise. Any idea's, I'm stumped?
2010 Monticeto by Thor
Thanks again for any help
  • Grinding noise from inside the door (lock mech)????
    Can also help if you let us know what make/model coach you own.
    My 07 Fleetwood has a remote to unlock/lock the door. Actual "box" is in between the fron seats (under the radio). Also, on the entry door you can see three pins/contacts. Those connect the locking mech when door closed. Needs to be clean.
    It sounds like a mechanical issue meaning it "might" need to be replaced.
    Again, let us know what make/model RV, others might have an idea whats going on.
    RM
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
