Buffalo716ny
Jan 22, 2016Explorer
Keystone cabana 2150 gets gas to stove and nothing else HELP
I've replaced the regulator and pigtails today hoping that was the problem still only get lp to the stove w nice flame .
If i hold down water heater pilot button there's no hiss of gas same w heater which operate but blows COLD air i can see the sail switch which is,moving when fan is active so I assume switch is good also pulled heater n blew everything out still no luck also the lp detection unit is plugged in ..any help much appreciate thanks
