flathead92's avatar
flathead92
Keystone
I have a 2020 keystone premier and like most the manuals spend more time covering there butts on safety. Anyway mine has a plug and says solar? So do I get a panel and plug in? Where do I find info on this ?
  • What BarabooBob said, I found the similar receptacle on the front corner of my Coleman, a 14 ga wire pair zip tied to the main battery cables. There's no controller. The actual plug was a ridiculous price at the dealer, but you can get them here. You may still have to insert a controller at the batter(ies) https://www.youtube.com/watch?v=yxYGaQX5GSQ
  • Most RV's that claim to be "SOLAR READY" only have a plug on the outside of the RV that leads to the battery. Most do not have a controller and many have wire that is not heavy enough to avoid a voltage drop between the panel(s) and the battery. You also must check the polarity on the plug to make sure you don't damage equipment or blow fuses.
Having RV issues? Connect with others who have been in your shoes.24,277 PostsLatest Activity: Jul 01, 2025
