joelmyer's avatar
joelmyer
KISAE SW1220 2000W, 12V Pure Sine Wave Inverter
Does anybody have one of these? Do you like it? Does it run your microwave ok?
here
  • smkettner wrote:
    I don't know anything about the inverter but the related transfer switch looks excellent for splicing into a single circuit.
    KISAE TS20A 20A Automatic Transfer Switch
    I like it better than the 15a Prowatt for the higher rating and having terminals vs the cords.
    Otherwise <3% is as good or better than most inverters.
    GoPower brand that I recommend has same spec at <3% THD.
    Hmmm. Like this one too.
  • 3_tons's avatar
    3_tons
    Seems very convenient, but 80 ms seems rather slow...
  • 5% THD is awful. Did not say not to buy the unit, just that 3% is a lot of waveform flex.
    Wonder how they establish their test values?
    Unloaded?
    Resistive Load?
    Inductive load?
    Full load?
    Percentage load?
    No load?
    One company might be testing one way the second, another.
    But there should be ZERO waveform distortion unloaded if the unit is intended for use with inductive loads like a microwave oven.
  • I don't know anything about the inverter but the related transfer switch looks excellent for splicing into a single circuit.
  • Mex wrote:
    <3% THD is not impressive in my book. Compare THD value to that of top PSW inverter brands. With inductive reactive loads such as a microwave THD limits are important.
    Incredibly low THD is why I chose a KATO brand AC generator rather than a LIMA or Stamford.
    IMHO
    <3% THD is actually a very good specification
    Compare it to the <4% Morningstar specs their PureSine 300 with
    Guess it's not a good inverter with such a specification
    Not sure what the Magnum units everyone raves about are speced at but would venture a guess it's 3 or 4% at best for THD
    Yes these units are made in China but pretty much everything is now days
    For <$300.00 it looks like a deal
    Just took a look at the High End Magnum inverters
    They spec the THD at 5%
    Guess they are not any good :h
  • <3% THD is not impressive in my book. Compare THD value to that of top PSW inverter brands. With inductive reactive loads such as a microwave THD limits are important.
