Community Alumni
Apr 06, 2009Oregon Chief wrote:
Bob,
Great work on the Kwikee step posts. One question, the answer to which I may have overlooked. When removing the motor, should the steps be retracted or extended? Makes sense that they should be retracted but I want to make ceretain. Thanks for your asssistance.
Oregon Chief,
what I did was disconnect the linkage pin and extended the steps out of the way I had a block of wood hold them out and away then replaced the link pin after I was done. Main thing is make sure you disconnect the step wires from the coach wires there is a connector about two feet or so from the steps. You dont want to be under there with power to the motor, just incase it decides to work or at least be very cautious with your hands and fingers. I like disconnectiong the linkage pin and propping the step out and up.
