- JohnRaExplorerMy leveler isn't affected by the battery disconnect. The disconnect seems to only affect systems inside the RV like lights.
- DuckExplorerMy first step in fixing electronic problems is to unplug the item, wait 30 seconds and then plug it back in. Fixes a lot of problems.
Don - FYI: LCI maintains a telephone technical support line 24/7/52. The phone number should be in your Level-Up owners manual.
- dbblsExplorerThanks for the information. So far I have not had any problems with mine.
- JSS1439ExplorerFixed it. Hit the battery disconnect for 15 seconds and reconnected and now all is working normal again. I guess LED screen just needed reset.
Thanks all! - JSS1439ExplorerOK just read on another forum to hold the retract and enter buttons down together. That stopped the beep and now allows me to raise and lower the front but the menu readout does not work to switch modes
