Juzaxadar's avatar
Juzaxadar
Leaking differential Ford E450
I found a slight leak in the front seal of the differential while I was checking for issues. I tried to get the fill plug out to top it off, and it's rusted shut. In fact, the 1/2" ratchet wouldn't even fit. No matter what I did I couldn't make it work.
picture:
After checking on prices to replace the seal I decided to replace the differential cover which includes a new fill plug. It'll be cheaper to just keep the fluid up.
Interesting stuff: Ford could not ID the differential based on the VIN or the door tag (axle = 81). The "non-rusting" aluminum tag on the differential itself was unreadable. I ended up spending a 15 uncomfortable minutes with my phone taking video under the RV to find some clue that this is a Dana 80 differential.
I ordered the cover and hopefully will get it next week in order to see if it fits.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
