happycamper002 wrote:
Try hooking up a 67 ohm resistor on one of the lamps and check the voltage on the other fixtures without the resistor and you will be surprised at the difference.
Of course you can get a replacement but it is much cheaper with a ten cent resistor from Radio Shack...and save the other LEDs.
You did not ask OP what kind of converter type he has. Was it Old School or Hi Tech.
Wonders of the internet. . . everyone turned into experts overnight.
:R
Your on the "internet" and I really don't see your answer is much of a "expert" type of answer..
The OP BOUGHT NEW and expected it to WORK right out of the box.
The vendor OWES the OP a WORKING item.
The OP should not have to add ANYTHING to make it work, PERIOD.
The VENDOR should make it right by exchanging it with no cost OR giving the OP their money back.
YOU are making some very wrong assumptions and cobbling a resitor into the circuit WILL NOT FIX the problem.
Simply put, there is TWO different setups with LED lights..
Setup one is to put all LEDs into a series/parallel arraignment.
White LEDs NEED 3.0V-3.8V forward voltage to light, typically THREE LEDs are placed in series.. More than three and they will parallel the additional strings together..
Typically a small value series resistor will be placed in series with the circuit to manage the current draw..
Not all that efficient.
Newer more efficient way to manage the current draw is to use a SWITCHING VOLTAGE REGULATOR to drive the LEDs. This regulator regulator is a constant current regulator.
Resistor current limiting has a very narrow voltage range 9V-15V)..
Constant current regulator has a very WIDE voltage range (typically 9V to 30V).
Now right now you are saying "so what?"..
Well IF the OP bought a resistor current limited LED array it would have burnt up and never worked again..
IF the OP bought LEDs which use a switching constant current regulator (Which IS most likely what the OP bought), the REGULATOR CAN cycle ON/OFF if it fails or over heats..
Most likely the OP bought cheaply made LED modules which have cheaply made regulators and no amount of resistors you add to the circuit will ever fix the problem.
And how you have come to the conclusion of using 67 ohms is way beyond belief.. You have NO idea how many LEDs are in series (IE wired), no idea of how much voltage or current the LEDs need and no way to determine the wattage of the resistors that the OP would need without sending the resistors in to a flaming mess.
You MUST be rather clairvoyant to know exactly how the OPs LEDs are wired and all the parameters of the LEDs or just a self proclaimed internet expert.. :R
