jaycocreek
Apr 20, 2021Explorer II
hold up therebig guy, yes you can use voltage in 10% aproximations
I believe this although my smart shunt voltage is slightly off because of any load I may have but the voltage meter that came on my battery box has been spot on voltage wise..So far I could actually come pretty close to actual voltage if I only used the voltage meter on my smart battery box,I have to let the smart shunt rest without a load to get a good reading even with just the Engel fridge/freezer cycling the voltage is lower...
