pnichols
Jul 08, 2015Explorer II
Mex wrote:
But skipping the purchase of an AGM brand because of a two-tenths of a volt disagreement between set maintenance charging voltage value and OEM battery recommendation, is just plain silly.
Now .... if one could just get the OEMs to agree that their published maintenace voltage values are silly if ever a warranty replacement becomes an issue between an OEM and a user.
BTW, if it's OK for all AGM batteries to use the same float voltage irrespective of electro-chemistry and construction .... I wonder why some AGM batteries off the charger sit week after week holding 13.1 volts on their terminals after being fully charged, while other AGM batteries off the charger sit week after week holding 12.8 volts on their terminals after being fully charged?
I have personnally seen this AGM terminal voltage difference during long-term non-use in my various AGM batteries in equipment, pickup trucks, boats, and RVs. The times have been too long, in my experience, for the differences to be due to surface charge bleed-off times.
It's hard to believe that all lead acid AGM batteries should act, and be treated, the same ... terminal-voltage-wise ... regardless of what combinations of materials and chemistry were used in their manufacture.
So far I'm willing to believe that this goes for float voltage differences, too. IMHO ... Lifeline, Fullriver, C&D Technologies, Rolls Surrette, etc. may agree with this, too.
