Cptnvideo
Oct 09, 2023Nomad
We have 5 206ah SOK LFP batteries that are only charged via solar & MPPT controller. My OEM converter is unplugged.
My settings are 14.2 volts bulk charge, then 20 minutes on absorb charge, same voltage, then float at 13.6 volts.
My MPPT controller has and will put out 100 amps which would be 20 amps per battery. Obviously, that output varies by time of day and season.
You don't have to fully charge LFP batteries nor do you have to charge at the 50% discharged point like flooded batteries. So this gives you a lot of flexibility when running the generator.
Answers here concerning the voltage settings will vary quite a bit. I gave you my opinion.
A little off topic, but you mentioned knowing not to run large loads off your batteries/inverter. We run an A/C unit (off solar & batteries) in the RV while traveling. Our drives typically are 3 hours or less. So you can run large loads IF your inverter and battery bank are sufficiently sized.
