- Ed_GeeExplorer IIThis is what my post is asking about.
https://www.ttnews.com/articles/diesel-exhaust-fluid-sensor-failures-sideline-thousands-trucks - TrackrigExplorer IIAlmost all of my friends own diesel trucks. Only the ones with Dodges have had the problem, especially on 2021 trucks. The local Dodge dealer had so many of them with problems it them a month to get to the last friend.
Bill - Ed_GeeExplorer II
Lynnmor wrote:
I believe that the Transit only comes with the small 3.5 engines and are not at all like the Super Duty.
Yes, the Transit 350 HD is a 3.2L turbo diesel, but the emissions controls are all similar in all diesel engines... with the stupid Limp mode required for all detected emissions failures, be they actual, or just sensor problems. - Grit_dogNavigator IIIConsidering they don’t run any of the same engines or transmissions, there probably isn’t any relationship between the 2 models and issues they may have.
- LynnmorExplorer III believe that the Transit only comes with the small 3.5 engines and are not at all like the Super Duty.
- ICamelExplorerI have a 2005 Ford F350 SuperDuty 6.0 Diesel. About 13 years ago an "over boost" condition(my fault) sent it in Limp Mode. I babied it to a point where I could pull off the road and it came out of Limp Mode after I shut off the engine and subsequently restarted it. Ford replaced the turbo under warranty. Hasn't ever gone into Limp Mode again.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
