PerryB67
Dec 19, 2022Explorer
TechWriter wrote:The following is from SOK's web site:
Did you get the SOKs with heaters?
SK12V206H designed for cold weather using! Can safely charge at temperatures down to -20°C (-4°F) by a standard charger or solar charger. The heater pads which draws power from the charger itself,battery cells no power lost.
The Sok heater only works when you are connected to a power source, i.e. plugged in at a campground, or during the day when you have adequate solar. If you're boondocking, when we would want a heater, they don't heat at night when it gets cold.
Enjoy,
Perry
Having RV issues? Connect with others who have been in your shoes.24,242 PostsLatest Activity: May 10, 2025
