BFL13 wrote:
I saw this while Googling about the 12v battery--some confusion and also Tesla might be changing to AGM in newer model cars--anyway if this is correct, the 12v battery is a 45AH sealed FLA that is charged by the car somehow using an algorithm set in firmware at 14.4, but outputs to the 12v things at 13.4. The 12 battery gets recharged when it reaches some lower SOC at some set-point I think ???? Not a clue.
Looks like you want to get at that 14.4 the 12v battery gets and not the 13.4 from the camping outlets and 7-pin?
Easy to measure the voltage in the cig lighter with your digital meter.
"The Hanhook 12V batteries in the Model Y/3 may not be AGM but it appears Tesla is charging them as if they were. I monitor the 12V post voltage with a Bluetooth voltage monitor. Anytime the car is awake the voltage is either 14.4V (actively charging via DC-to-DC converter) or 13.4V (DC-to-DC supplying power to 12V operational loads). Dropping to 13.4V did not happen until a fairly recent firmware update, prior to that it was always 14.4V when not sleeping. I purchased a NOCO Genius G7200 to maintain charge level, with the negative cable not connected, so the battery is not connected to the car while using the charger. The charge mode I use (or should I say the charger automatically selects) is 12V Cold/AGM. According to the NOCO manual the charge voltage in this mode is 14.8V (which is what my BT device measures). Neither Tesla nor the Smart Charger charge at 16V. If I am using the wrong charging mode, what mode should I be using? Note the BT monitor might be off by +/- 0.1V
From Hankook web page:
Charge for 24 hours as following voltage upon battery type.
- 12V MF Battery: 16V
- 12V AGM Battery: 14.4V
See this Hankook webpage for more info.
Battery Maintenance - Hankook AtlasBX Technical Information"
Good find, and good info.
I just did a test using the model 3 (should be the same for the Y) and by configuring the HVAC to manual with heat and AC off, the total loss was 2 percent of the main pack in 6 hours. Much better than auto. Still a big loss for nothing over 24 hours but would work in a pinch, or at night when no generators are allowed etc. Of course it would be higher once the DC to DC converter is connected to the accessory port. But it’s max 9 amps at 12 volts so that’s only an extra kilowatt over 9 or 10 hours. Think I’ll order the victron tomorrow. 80 bucks and free shipping. Should be a fun project...that I’ll probably never use. :). Always fun to tinker.- BFL13Explorer III saw this while Googling about the 12v battery--some confusion and also Tesla might be changing to AGM in newer model cars--anyway if this is correct, the 12v battery is a 45AH sealed FLA that is charged by the car somehow using an algorithm set in firmware at 14.4, but outputs to the 12v things at 13.4. The 12 battery gets recharged when it reaches some lower SOC at some set-point I think ???? Not a clue.
Battery Maintenance - Hankook AtlasBX Technical Information" BFL13 wrote:
Having an EV for a TV is a whole new thing! Very interesting.
Yah for sure. Most of the folks we have talked to towing with the model Y or the X love them. But they all say the same thing. Great tow vehicles for short or medium trips with small trailers. But if you want to make time going across the country then by a truck or big SUV with a big gas tank. We typically don’t travel more than a couple hours a day when touring so I’m sure it will be fine for us. And with 450 hp I’m sure it will tow fine.- BFL13Explorer IIHaving an EV for a TV is a whole new thing! Very interesting.
When you wheel up to the EV charging station with the trailer (with its LFPs) hooked on, you should be able to do both the EV and the trailer! :) BFL13 wrote:
Interesting about the Tesla, thanks. What about voltage to the 7-pin and the camping 12v sockets? You can run things at 12v, but actual battery charging requires more like 14v or so.
With a gasser, you use the DC-DC to boost the engine battery voltage from 13.8ish to 14.6ish. Charging at 13.8 is lame. The Tesla might only be giving you 12.6ish or whatever to run your camping things and the 7-pin for trailer signal lights?
Sounds like the portable gen is going to get a lot of work!
Our present tesla (Model 3) doesn’t have a 7 pin so no way to check what’s on the charge line. Our model Y delivery date is tentatively February so have to wait till then to check.
We don’t dry camp a lot but when we do it’s usually for a week....and under trees. I suspect I would have to run the genny at least once a day for 45 minutes. Maybe twice a day depending how cold it is as the hydronic heating system has a pump that draws a couple or so amps when called on. Then again. A fantastic fan does as well. We’ll have to wait and see.
I’m looking at a victron dc to dc 9 amp converter so I don’t have a double conversion. I received a tip on how to run camp mode in a lower current draw mode. I’m running a test on it right now. Gotta do something until we can go camping. :).- BFL13Explorer IIInteresting about the Tesla, thanks. What about voltage to the 7-pin and the camping 12v sockets? You can run things at 12v, but actual battery charging requires more like 14v or so.
Sounds like the portable gen is going to get a lot of work! pianotuna wrote:
Reisender wrote:
You are from BC so you know we are kinda blessed with charge infrastructure here and it’s growing super fast as well.
three years ago there were 37 charge points in Regina. Over 1/2 were free to use.
Good to hear Don. I haven't looked at a map of that area on plugshare lately. Sounds like infrastructure is growing.
Cheers.BFL13 wrote:
No clue about EVs. Can you use a DC-DC charger instead of the 7-pin like you can with a gasser? The limit with those is the alternator amps vs the DC-DC input so not to over-task the alternator. What happens with an EV?
Well, I'm definitely not an expert in this kind of thing, but I can tell you the way I understand it.
So, EV's still have a 12 volt battery for providing power to things like lights, fans, heat pumps etc etc and of course the charge line on the 7 pin connector. The 12 volt battery gets its power from the 82 kwh 400 volt motive pack via a DC to DC converter. But, at least in a Tesla, you can't just connect a load to the 12 volt battery and this is why. All outputs from the 12 volt battery are monitored. If you hook up a separate DC to DC converter to just charge a separate battery external to the car, (like the trailer battery) it will detect that more current is going out of the battery than coming in and it will throw a code. I'm not sure of the consequences of that.
So the only other choice is to use the accessory 12 volt plug in the dash or the one in the hatch area. These will provide 12 amp continuous or 16 amp peak power so one can power an inverter and in turn power a small battery charger. I'm sure there are DC to DC converters out there that would work but I couldn't find any.
However, there is a catch. The car needs to be in "camp mode" for those to work. Camp mode is a tesla feature that allows you to car camp. Keeps the display on for watching movies, keeps the HVAC on for staying warm or cool and allows access to all the USB and accessory ports for phones, coolers etc. However, this typically drags the main pack down about 18 percent per day depending on the weather. This is why I think it is a super inefficient way of keeping a trailer battery charged.
A little story. We have a 2 KWH UPS in the house for critical loads like the fridge or entertainment centre. (We need to be able to watch zombie movies during power outages). Good for about a day of power outage. Works well. But last year we thought about in an emergency extending that using the Tesla. So we actually went thru the motions of getting a little inverter and 7 amp battery charger, putting the car in camp mode and hooking it up to the batteries of the house UPS. Worked great, Kept up but got pretty warm. We ran it for a day to prove it would work and then called it quits. And yep, sucked the car battery down 18 percent, almost all of which was wasted running the various systems of the car. So yah, definitely NOT the way to go when camping. A 700 dollar super quite propane inverter generator is a much better way to go.
Here is a pic of what we used. Like I say, once we get the trailer we'll figure it out pretty quick. Our first long trip is from the interior, up the island, ferry up the inside passage to Prince Rupert and then a great circle back to the Okanagan. Figure 6 or 8 weeks should do it. Lots of hiking coming up. :)- srschangNomadBefore I bought my 2 Battleborns a few years ago, I did a ton of research trying to convince myself they are worth the money. I seem to remember that the 100ah Battleborns are actually like 110 or 120ah. They set the bms to limit charge and discharge so the battery can only use 100ah. That way the battery never charges fully and never discharges fully, but you still get 100 useable ah. The battery does the 10-90 for you automatically.
- BFL13Explorer IINo clue about EVs. Can you use a DC-DC charger instead of the 7-pin like you can with a gasser? The limit with those is the alternator amps vs the DC-DC input so not to over-task the alternator. What happens with an EV?
Watch the gen VA vs the input for the charger. A 2000w does 1600VA which is borderline for a 60 amp charger doing 60 amps at 14.4v. A "2200w" does 1700VA most of them or 1800VA if a Honda. My 1700VA gen is maxed out with my 75 amp converter, but it runs it--just barely until amps taper and it gets easier on the gen.
You are right IMO to try it all out first and then see what needs doing. by the time you get it, the sun might even come out and not be raining so much, which should help. " If you can't see the mountains it is because it is raining; if you can see the mountains, it is going to rain"
Not suggesting SiO2 --I just happen to have them. LFP inside where it is warm is the answer here. My other big point is you don't have to do anything to the existing wiring and converter with the nice new rig and the size and location of the OEM battery box doesn't matter either.
Just meant as an idea that might work for some situations that have come up for TCs or small TTs.
