- Rover_BillExplorer IIDew Point temperature (wet-bulb temp) along with the air temperature (dry-bulb temp) is measured by a psychrometer. I'm not aware of any inexpensive devices that contain a psychrometer to display an accurate wet-bulb temp.
An accurate Relative Humidity is derived from those wet/dry bulb reading. Many mechanical (analog) and electronic (digital) instruments only give a gross RH approximation. If that RH value is calculated back to a wet-bulb temp from those displays, the margin of error would be +/- 5 degrees (or more). That error makes a dew point temp display grossly inaccurate.
Oregon Scientific sells a nice line of home weather instruments. THIS is the one I have in my trailer. - stacaz822Explorer
How about this one. I don't mind +- 4%.... https://www.homedepot.com/p/Extech-Instruments-Big-Digit-Humidity-Alert-Hygro-Thermometer-445814/203711583?cm_mmc=Shopping%7CG%7CVF%7CD27E%7C27-11_TOOLS_%26_ACCESSORIES%7CNA%7CPLA%7c71700000033101173%7c58700003868916496%7c92700031085777931&gclid=Cj0KCQjwn_LrBRD4ARIsAFEQFKvDGCvQSwWv5Oue4CXuhmQZJ1Bcj6m2ZBZEmmaQlXFDgpgUrJOUz5EaAqLwEALw_wcB&gclsrc=aw.ds
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
