wnjj
Aug 14, 2018Explorer II
valhalla360 wrote:You’ll want communications in a separate conduit above the electrical in the same trench.
Go big on the conduit...as you learned with the old conduit...If you want to run communications or 50amp line later, it's much easier if you have a 2" or even larger conduit to work with and the cost difference is negligible.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
