MrWizard
May 03, 2018Moderator
I would be thinking that same way
But
The question arises, what size is the hole in the step where the rivet passes thru, won't know until you remove the rivet aka the diameter of the rivet
Will there be a standard diameter shoulder bolt that makes the right fit
Or will it need a sleeve, or need to be turned down
It wobbles, so there is wear, is the hole now out of round?
Is there enough material to enlarge the holes and install a larger bolt?
But
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
