3GageBoys's avatar
3GageBoys
Losing Electrical Power when motorhomes engine is started.
Looking/Hoping to find someone that might have had this issue that can
help resolve this problem. The motorhome is a 2013 Thor Outlaw (Class A)
The problem my buddy is having is that the moment he starts the engine on the motorhome he will lose all 110 electrical power to the coach.
This will happen both when he is plugged into the shore power and/or
running off the generator. He has been on the phone with Thor and they have sent him a new inverter last night and he installed and tested that a few hours ago and is having the same results. He has full power
when the motor is not running. The only time that he was able to
correct the problem was when he disconnected all the batteries to the coach(House and Chassis) and when he tested it worked like it should until he shut the engine off and then restarted the power kicked off again. Thank you in advance for your time and effort in helping us get this problem resolved!!!
Thanks
Sid Gage
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
