wabrower01
Nov 20, 2017Explorer
Macerator Pumps Real Slow
I had the macerator pump replaced on m Roadtrek (RS Adventurous) last week. The Roadtrek authorized dealer installed the new pump. Their technician verified the pump did actual pump. When I got home, I filled the gray tank and starting the macerator pump after opening the gray dump valve. It pumped a half gallon in about 30 seconds. It is a Shurflo, and I called their customer service help line. Was told could be a low voltage (should be 12.5 - 13volts) or it could be wired wrong - in that case the assumption is the impeller is reversing. Anyone with similar experiences with a macerator pump? I'm bring the Roadtrek back into the authorized dealer next week to check it out.
