All_I_could_aff's avatar
Nov 09, 2019
Magnetek 3230 power converter problem
My friend recently asked my help with his 10 year old 26 foot trailer that sits permanently on a site in Pennsylvania about 105 miles from my house. The complaint is that while all 110 V functions work fine, very few 12 volt functions work. He recently installed two new group 27 batteries on the tongue. He did not have a test light with him, so I had him pull each fuse one at a time for visual inspection. He said all looked good.
I packed up my electrical tools and drove out today to help him figure this out, because he was unable to power in the slides as part of winter preparations. The first thing I noticed was that only three out of the nine fuse ports had power on the input side ( the ones under the green line). The other six ports under my red line did not have power.
I temporarily moved some of the output wires from the dead circuits to the right side and each feature then worked properly and we closed the slides. I imagine there is some sort of bus bar running on the backside of this panel from the main red positive post feeding the top of each fuse terminal that may have broken between the third and fourth position. Any thoughts before I proceeded?
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
