Tambs
May 16, 2020Explorer
Magnetek series 7300, Model 7345 Converter
Hello all,
I have a 1998 Lance Legend 500 truck camper that uses the above converter. I’ve been having battery issues lately, and after removing the 12V house battery I found it is sitting at 6.5 volts. The camper has been plugged in to 120V shore power. The battery is an Optima Blue Top, but it is 8 years old so I’m confident it is shot and needing to be replaced.
After removing the battery I checked the battery leads with a voltage meter and only got 5.2V coming through the leads. I then checked the truck batteries and found them to have 5.75V. I disconnected the truck pigtail from the camper and voltage at the battery leads was 0 (with shore power plugged in and confirmed to be hot). So apparently the converter isn’t supplying any power to the house battery. The converter output terminal (circled in red in the pic below) at the fuse panel adjacent to the converter itself registers 13.8V when plugged into shore power, but the battery lugs (circled in blue) coming off of the same fuse block read 0V. All fuses are good.
Is it logical to conclude that the converter has failed, or is there something else I should check before seeking out a replacement converter?
If a replacement is in order, what would you recommend? I’d prefer an AGM battery, and from what I can tell they require smart chargers. Is there a direct replacement for the 7345 that incorporates smart charging technology?
https://www.amazon.com/photos/shared/1ezGjXdbRHyDjPsf2rGuog.pKf0JdNicc67CftZXuLkCJ
