NMVistaowner's avatar
NMVistaowner
Major electrical issue
I have a 2014 Winnebago Vista. Last night we heard a loud sound and immediately smelled electrical burning. Best I can tell, a wire loosened, connected with another wire and.....meltdown. I haven't been able to find a new transfer relay switch on a Sunday and don't know if there was any additional damage done to the system so here is my question: Without shore power or generator, can I still use my inverter for power? I certainly don't want to do any additional damage to the system and I'm not scheduled for repair until this coming Friday. Thanks in advance for any answers.
  • NMVistaowner wrote:
    Best I can tell, a wire loosened, connected with another wire and.....meltdown. I haven't been able to find a new transfer relay switch .
    So, you're sure it's the xfer switch? Doesn't sound like you're all that sure about it.
  • wa8yxm's avatar
    wa8yxm
    Yes you can use your inverter for short periods provided it has a transffer switch of its own.. Now I can bypass a auto transfer switch.. but alas I do nto feel comfortable telling others how.
    If the transfer switch is a 3-way (Short/Genny/Inverter) and no inverter sub panel I would avoid all 120 volt use.
    In my case the line is like this (simplifed stuff left out)
    Shore---ATS--_main breaker box--Branch (30 amp)--Inverter---Sub panel--Stuff
    If yours is like that you can still run the "Stuff". But not for long cause it eats batteries.
    Oh. I do have a way to plug in my converter independent of the RV that extends the "Stuff" run time to.. Forever
  • Assuming you have an inverter/charger, IMO don't use the inverter for 120v just yet. A straight inverter could be used from battery power, but not by using the shore power cord for "whole house" with that damage.
    Perhaps with the inverter/charger (assuming it is not showing faults), you can disconnect its output 120v that goes to where the damage is, and connect a new 120v cord that has receptacles on it, so you can plug in an appliance or two to get by.
    You will need to recharge the house batteries somehow.
  • I would avoid all 120 volt operations!
    Depending on your ability, you could wire around a bad transfer switch.
Having RV issues? Connect with others who have been in your shoes.24,240 PostsLatest Activity: Apr 26, 2025
