Junior30's avatar
Junior30
Major short in generator wiring - Pictures
Had a major short and near fire due to the wiring from my generator this past weekend. While on the road we had the gen running with the a/c going. The wife went to use the microwave and when she did everything shorted out. We have used all appliances while on generator power before with no issues.
Upon arriving back home I traced back the problem to a junction box in a compartment just after the generator. I found evidence of a major short in the wires. It appear as though the wires may have come loose and separated slightly causing the short.
One concern I have is the wires from the generator are some type of stranded aluminum wiring and the wires running from there to my transfer switch are solid copper. Could the dissimilar metals be an issue? Should I, Can I replace the wires coming from generator?
Judging from the photos this could have been worse especially if the wires had not been inside of a junction box.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
