jharrell
Aug 30, 2018Explorer
pianotuna wrote:
So that I can do a recovery on the AGM's when that becomes needed. At 77 f (25 c) lifeline suggests recovery voltage for 8 hours @ 15.48 volts.
Did you look at using the equalization function? You can set voltage and hours, then you hold down the charger button for 5 seconds while in float and it will do the equalization charger, even had a reminder in days that can be setup.
