- gatorcqExplorerThe nice thing about Magnum, is the Custom Battery settings.
Once you ID the specific battery charge, you use the custom mode.
Next step will be Lithium - Magnum makes it very easy to setup. - pianotunaNomad IIIHi jharrel,
Thanks for that information on the equalize function. - jharrellExplorer
pianotuna wrote:
So that I can do a recovery on the AGM's when that becomes needed. At 77 f (25 c) lifeline suggests recovery voltage for 8 hours @ 15.48 volts.
Did you look at using the equalization function? You can set voltage and hours, then you hold down the charger button for 5 seconds while in float and it will do the equalization charger, even had a reminder in days that can be setup. pianotuna wrote:
I think we all assumed you were setting bulk/absorption.
Hi,
I was toying with my charge voltages. I wanted to try 15.4. When I set 15.4 on the remote it did not get above 14.7 volts. The bank was fairly full so it was only doing between 8 and 10 amps of charging.
Does anyone know the maximum dc output voltage?
I did post that there must be some other limit.- pianotunaNomad IIITime2roll,
Since the computer boards in the RV can't withstand more than 15.4 I thought that with temperature compensation that would be enough to do the deed. - Why would you set float to 15+ ???
- pianotunaNomad IIIJohn,
Thanks to jharrel I discovered absorb setting has to be higher than the float value. All is well. - full_moseyExplorer
pianotuna wrote:
Hi,
Do you have a Voltage cap set? The cap might be lower than the 15.4V Abs you are trying with the result that your cap setting is overriding.
Does your Battery-Temp-Sensor work. I did once have a faulty one from Magnum. It could have been the circuit board though as I ended up exchanging the entire inverter and BTS cable.
HTH;
John - jharrellExplorerThought that might be it, doesn't make sense to have float higher than absorb, wish they would note that behavior in the manual though. Was about to go out and try it myself.
- pianotunaNomad IIIjharrel,
Bingo! You have to reset absorb to a higher number than the float. (give yourself a gold star!)
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
