swimmer_spe
Apr 22, 2021Explorer
missing cover
I have a cover that flew off of my trailer. It covered the opening for the propane fridge. Would it be possible to just make a frame out of wood, cover it with screening and it be safe?
swimmer_spe wrote:
https://www.amazon.ca/Dometic-3109350-011-Polar-White-Lower/dp/B004LELY6K
I think that's it. I'll measure it and go from there.
The one on the side, yes but a replacement is probably pretty inexpensive.
It is a 1999 Rockwood Ultra light 24 footer. If you can find one, that would be great!
enblethen wrote:
What brand of refer?
Call rig help support line. They maybe able to tell what they used.
dougrainer wrote:
1. 1999. There are only 2 access door makers. Dometic or Norcold. Both are available. There are different sizes so make sure you measure your existing hole. Also, a Norcold refer may have a Dometic side vent and Vice Versa.
2. DO NOT install ANY type screen on the side access door louvers. The purpose of the side door and louver cut outs are to get a certain volume of fresh air IN and up the back of the refer Cooling unit. ANY type screen material will block off about 50% of the volume of air needed to adequately operate the refer to cool correctly. Doug
