dieseltruckdriv
Jan 09, 2022Explorer II
pianotuna wrote:Skibane wrote:
You'd think that if there was a significant danger associated with catalytic heaters, there would be at least one published news story about some hapless RVer being killed by one.
It happens frequently enough that it is no longer newsworthy.
A blue flame heater may self extinguish before oxygen levels become too low to support life. A catalytic heater will quite merrily continue to work at extremely low O2 levels. Of course, as O2 goes down, CO increases.
There are many through the wall heaters that do not need electricity. They cost a little more, but are MUCH safer.
You may do as you wish Skibanel, and I'll continue to NOT use an unvented combustion heater while sleeping.
Hmmm, you gave me something to check. I am going to test at what O2 level my catalytic heater stops working. The literature says it will not go below a safe O2 level, but I can check mine. This is something I always point out, it is mine, not all of them.
I will build a small enclosure in my unattached garage and see at what O2 level it self extinguishes. Actually I think it will do it outside, in case of fire danger. Oh, by the way, I was also a deputy chief on our fire department before I was forced to retire for medical reasons. The test I have in mind just screams fire danger, but that is the best way to test for CO. ;)
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
