โSep-25-2010 03:17 PM
โOct-27-2010 04:22 PM
MrWizard wrote:
you seem to be superimposing "constants" that don't exist , on a static unused bank, setting in the middle of nowhere exposed to constant sun,
this is not a lab setting doing a controlled durability test,
โOct-27-2010 02:37 PM
โOct-27-2010 02:22 PM
Salvo wrote:
.... Gassing begins above 13.9V. It's important to note, gassing is a function of battery voltage, not current. If the battery voltage rises to 14.6V, then there's enough current to make it happen.
โOct-27-2010 01:47 PM
Salvo wrote:
I can only surmise you're not comprehending what's taking place. The factory voltage setting is 14.1V. MrWiz cranked this setpoint voltage up to 14.7V. Gassing begins above 13.9V. It's important to note, gassing is a function of battery voltage, not current. If the battery voltage rises to 14.6V, then there's enough current to make it happen.
As a homework assignment, do your own research & analysis to the rest of your questions.
โOct-27-2010 01:42 PM
MrWizard wrote:
just measured
15.67v panel voltage into controller
14.44v at controller output
13.55v at batteries
12.20amps controller output
that 14ft run 4ga has 0.89v drop at 12.20 amps
โOct-27-2010 01:34 PM
BFL13 wrote:
How can the controller crank out so much more than the battery will accept and create this gassing problem when it is designed to not do that?
โOct-27-2010 01:22 PM
โOct-27-2010 12:49 PM
โOct-27-2010 12:13 PM
โOct-27-2010 11:18 AM
โOct-27-2010 10:20 AM
MrWizard wrote:
current voltage readings: from panels 14.53 into the controller with an 8.52 amp output from controller, output voltage measures 13.52 @ controller & 13.02 @ batteries
โOct-27-2010 10:09 AM
โOct-27-2010 10:02 AM
โOct-27-2010 09:01 AM
โOct-27-2010 08:43 AM
