Sep-25-2010 03:17 PM
Dec-11-2010 09:47 AM
Dec-11-2010 09:11 AM
pianotuna wrote:
You misunderstood I believe. The glass heats in traditional panels and it is a pretty good insulator, so the panel remains hot longer. Part of that is because it is heavier to start with, i.e. more massive.
The Unisolar panels will cool down faster, and radiate better.Salvo wrote:
I hope they're not teaching that at our schools now.
The mass of the glass has little effect on heat dissipation. The prominent factor in heat dissipation is surface area. These panels have half the surface area. It's a no-brainer.
Salpianotuna wrote:
Heat dissipation is superior in non glass panels, as they have less mass.
Dec-11-2010 08:38 AM
Dec-11-2010 08:13 AM
Dec-11-2010 07:48 AM
HobbyTalk wrote:
Their ad sounds a bit "snake oil" to me. They claim their 68W panel will recharge 2 6 volt batteries in 7 to 10 hours. How is a 68W panel going to recharge a 220Ah battery pack in 10 hours? That's not even enough to recharge a single 100Ah 12v battery that has been discharged to 50%.
Dec-11-2010 07:26 AM
Dec-11-2010 06:32 AM
Dec-11-2010 06:09 AM
vcallaway wrote:
I'm not a fan of thin film panels. They require more surface area to generate the same amount of power. They also degrade faster than standard panels. Probably not an issue for an RV though.
I also agree about air flow. Thin film panels are subject to the same heat issues as any other. The air gap does make a difference.
Dec-11-2010 05:44 AM
Dec-11-2010 05:38 AM
Dec-10-2010 10:14 PM
Dec-10-2010 10:12 PM
Dec-10-2010 02:02 PM
Dec-10-2010 01:25 PM
MrWizard wrote:
Tuesday Dec 7th, 14 days from winter.Solstice
707.7 Whrs
51.37 Amphrs
10.46 peak amps
146.20 peak watts
Dec-09-2010 05:39 PM
