Sep-25-2010 03:17 PM
Dec-01-2010 12:41 PM
Nov-30-2010 05:24 PM
Nov-13-2010 08:08 AM
Nov-13-2010 06:12 AM
Nov-13-2010 05:15 AM
Nov-13-2010 04:59 AM
Nov-11-2010 09:08 AM
Nov-11-2010 08:59 AM
Nov-01-2010 08:47 AM
Nov-01-2010 07:03 AM
MrWizard wrote:What inverter did you decide to get?
no data. meter reset disconnected batteries while removing failed Freedom-10 inverter-charger
Oct-31-2010 09:10 PM
Oct-29-2010 07:23 PM
Oct-29-2010 11:14 AM
Salvo wrote:
Setpoint has everything to do with the MPPT efficiency. First off, the controller doesn't know the voltage of the battery. It calculates the most efficient power point by using the voltage at the output of the controller, not battery voltage. There is no battery sense line.
Of course there is no "sense line" but the controller has the charge wires attached to it that are basically sense wires because the controller will react to a load/ low battery.
Blue Sky Energy - Solar Boost 2000E
Because output power is constant while MPPT is operating, anything that leads to lower battery voltage will produce an increase in Output Charge Current. While a discharged battery is one way to produce lower output voltage, and therefore higher output current, other normal conditions may produce lower voltage as well. Any 12 volt power consumption during the day will decrease net battery charge current, which decreases battery voltage.
There are a few bad things happening with a high setpoint.
1. The higher the setpoint, the smaller the difference between controller input and output voltage. You've now eliminated the advantage of MPPT. MPPT wants to see a large voltage difference between input and output.
There are two adjustments on the 2000i. One for Mppt and the other is for Setpoint. I have played with these settings.
Some controllers do the matching without performing a panel match adjustment.
From the Bluesky 2000I manual:
OPTIMIZING MPPT 2000I:
The maximum power voltage setting (VOC - VMP) is a nominal value. The combined effects of manufacturing tolerances in the PV panel and wiring resistance in a particular installation can sometimes shift the optimum setting.
While not required, it is recommended that for maximum boost performance this adjustment be fine tuned following
installation. Fine tuning is also desirable following installation of additional PV panels.
Fine tuning is easily accomplished by slowly adjusting the MPPT adjust potentiometer to obtain maximum
Output Charge Current. Adjustment is best done in full sun with a discharged battery and cool ambient
temperatures. Verify that a slight drop in output current is seen on either side of the peak. If a drop on either side of
the peak is not seen, MPPT is not fully operational due to a combination of high PV temperature and/or high battery
voltage. MPPT can usually be made to operate by lowering battery voltage through application of a heavy DC load.
If in doubt, leave the adjustment at the factory setting position as shown in Figure 3.
2. The higher the converter output voltage the lower the charging current.
3. Gassing increases. Battery overcharging.
BTW Jim, you better read the Blue Sky manual before giving false information.
Have read and performed the adjustments...I had the Morningstar Sunsaver in my mind.
Salbigfootford wrote:
Mppt is a function/feature that a controller does and has nothing to do with the setpoint.
The BlueSky 2000e can reach setpoint in either Mppt mode or PWM...
Jim
If a controller has the setpoint feature then when the setpoint voltage is met which is the output of the controller to the battery then the controller will revert to the absorb voltage which is lower than setpoint. The Absorb voltage is usually low enough to stop gassing.
I stand corrected...Several other Mppt controllers do drop to a lower absorb voltage but the 2000i does not.
This is just one of the reasons I ended up with the Morningstar sunsaver.
Jim
Jim
Oct-29-2010 09:34 AM
Oct-29-2010 07:53 AM
