MrWizard
Sep 25, 2010Moderator
More Solar for "Us"
Ok, I went off.the deep end?
Bought 3 used 37watt uni-solar panels and a blue sky 2000e controller for the hefty price of $400,
They were being listed as 75w panels, they are not
The tested open circuit voltage was 21+, short circuit amps 2.9
I tested each panel multiple times tilted into the sun and laying flat on the ground , got the same readings each way, that was the deciding factor, they appear to put out full power while laying flat, I will try to mount them tomorrow before it gets hot, right now 104°F
I will use the existing wiring until I buy & install the new wire
